cheekymonkey Posted January 5, 2008 Share Posted January 5, 2008 Hi All Finally working through the last little niggles with the car now that the suspension is sorted After heavy rain I get water at the bottom of the door when I open it, and my seatbelt comes out of it's slot feeling rather soaked, but it dries out quickly. Seems to be happening since the door was taken off and re-fitted. Are they any adjustments that I can do to sort this out? Quote Link to comment Share on other sites More sharing options...
Dave F Posted January 6, 2008 Share Posted January 6, 2008 I had the same damp seatbelt problem and it turned out to be water coming in through the rear side window. I removed the trim inside and used silicone and also put some clear silicone on the outside in the guttering. Worked a treat. As for the door has the plastic liner been removed and are the drain holes blocked at the bottom? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 6, 2008 Share Posted January 6, 2008 It could be water getting past the window seal that runs horizontally on the top of the door, I had this and got water leaking inside the door. A new window seal sorted the problem. Give me a shout if you need prices for the seals. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 6, 2008 Author Share Posted January 6, 2008 Thanks guys, I need to wait until its light and try and work out exactly where it's coming from. Quote Link to comment Share on other sites More sharing options...
