adam bell Posted January 4, 2008 Share Posted January 4, 2008 my front washer have stopped working on the supra but the back one still works fine,i dont know what to check first having not had the supra long i dont want to start messing around with it. any ideas will be a great help. Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 4, 2008 Share Posted January 4, 2008 Can you hear the motor running?? I have blocked mine with car wax before ??, if you can not hear the motor check the fuse maybe Link to comment Share on other sites More sharing options...
adam bell Posted January 4, 2008 Author Share Posted January 4, 2008 cant hear the motor running i might unplug the bonnet jets and see if water comes out the hoses if that would work. Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 4, 2008 Share Posted January 4, 2008 If it does a small pin will clear the jets but be careful Link to comment Share on other sites More sharing options...
Nic Posted January 5, 2008 Share Posted January 5, 2008 May sound a silly question, but you are pushing the button on the end to operate the washer jets? Link to comment Share on other sites More sharing options...
AndyRick1 Posted January 5, 2008 Share Posted January 5, 2008 If back washer works the motor is ok ,as both the tubes for front and rear washers comes of the same motor, baybe the tube has come away from the motor? Link to comment Share on other sites More sharing options...
ivan Posted January 5, 2008 Share Posted January 5, 2008 Most likely to be blocked jets. Just clear them out carefully with a pin. Link to comment Share on other sites More sharing options...
adam bell Posted January 5, 2008 Author Share Posted January 5, 2008 thanks to nic for your tip lol all sorted now,might go and bury my head in the sand Link to comment Share on other sites More sharing options...
hiten55 Posted January 5, 2008 Share Posted January 5, 2008 thanks to nic for your tip lol all sorted now,might go and bury my head in the sand wouldnt be the first mate Link to comment Share on other sites More sharing options...
