Matt H Posted January 3, 2008 Share Posted January 3, 2008 The following pertains to an apparent difference in design from the normal “coupe” hardtop supra to the aerotop; The interior bits are currently being swapped over from my coupe into the aerotop, however, the rear seats wont fit properly due to some additional catches or elements that Chris at hyper has said looks like there should be a form of strut bar (for example) running in between for strengthening (due to the aerotop?). This "addition" is found behind the rear seats but before the stock subwoofer (which is found in GZ's) I’ve asked Chris to take a picture to help explain things better, but in the meantime, does anyone know what I’m trying to describe here? What exactly are these two things, and should there be a bar running in-between them? Is it strengthening? And as such is it an essential part that needs replacing or are these two things just redundant? Thanks on advance Matt Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 3, 2008 Share Posted January 3, 2008 Its probably one of these, like you can get from MVP: http://www.mkiv.com/techarticles/doluck_floor_brace/index.html and (14th item from top) http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=799&SearchYN=N Its a floor brace that goes behind the front seats to strengthen, and control, the 'flex' you might experience with the roof off. I want one of those Quote Link to comment Share on other sites More sharing options...
supradibbs Posted January 3, 2008 Share Posted January 3, 2008 Its probably one of these, like you can get from MVP: http://www.mkiv.com/techarticles/doluck_floor_brace/index.html and (14th item from top) http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=799&SearchYN=N Its a floor brace that goes behind the front seats to strengthen, and control, the 'flex' you might experience with the roof off. I want one of those NOPE I VERY MUCH DOUBT IT CANT THINK WHAT YOU MEAN MATT JUST LOOKED AT MINE AND CANT SEE WHAT THIS MAY BE PICS WOULD HELP Quote Link to comment Share on other sites More sharing options...
captainchaos Posted January 3, 2008 Share Posted January 3, 2008 me neither had mine to bits not too long ago too Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 3, 2008 Author Share Posted January 3, 2008 Its probably one of these, like you can get from MVP: http://www.mkiv.com/techarticles/doluck_floor_brace/index.html and (14th item from top) http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=799&SearchYN=N Its a floor brace that goes behind the front seats to strengthen, and control, the 'flex' you might experience with the roof off. I want one of those Does the dog come included in that first one?! But no its not aftermarket, otherwise id have no problems just getting rid Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 3, 2008 Author Share Posted January 3, 2008 NOPE I VERY MUCH DOUBT IT CANT THINK WHAT YOU MEAN MATT JUST LOOKED AT MINE AND CANT SEE WHAT THIS MAY BE PICS WOULD HELP me neither had mine to bits not too long ago too ummm, could this be a facelift aerotop thing then? Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 3, 2008 Share Posted January 3, 2008 Does the dog come included in that first one?! But no its not aftermarket, otherwise id have no problems just getting rid Oh maybe it was wishful thinking on my part, sorry Quote Link to comment Share on other sites More sharing options...
TrickTT Posted January 3, 2008 Share Posted January 3, 2008 There are lots of strengthening brackets in an aerotop that you dont find in a hard top, but nothing where you are describing. Need pics. Quote Link to comment Share on other sites More sharing options...
supradibbs Posted January 3, 2008 Share Posted January 3, 2008 ummm, could this be a facelift aerotop thing then? Am wondering the same thing there is nothing that i can think of that would hinder install of the rear seats at all get some pics up Quote Link to comment Share on other sites More sharing options...
Faye Posted January 3, 2008 Share Posted January 3, 2008 ummm, could this be a facelift aerotop thing then? I've never had any problems with the rear seats in my facelift aerotop- I've replaced mine with some leather ones off a prefacelift and they popped in just fine. Quote Link to comment Share on other sites More sharing options...
supradibbs Posted January 3, 2008 Share Posted January 3, 2008 I've never had any problems with the rear seats in my facelift aerotop- I've replaced mine with some leather ones off a prefacelift and they popped in just fine. maybe his chassis is still twisted:d Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted January 3, 2008 Share Posted January 3, 2008 Sounds like a rear strut brace. The strengthening in the aerotop is mainly with extra plates spot welded on in the back seat area. Dude showed me once. You wouldn't notice them normally unless pointed out. I put a rear strut brace across the two rear suspension struts the same as the front ones. Stiffened my car up a treat with the roof out. It sits in pretty much the area you are talking about ie directly behind the rear seat over the top of where the stock sub is. Hang on a mo you aren't talking about the two fwd mounts that the roof sits on in the boot are you? Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 4, 2008 Author Share Posted January 4, 2008 The strengthening in the aerotop is mainly with extra plates spot welded on in the back seat area. That does sound indeed what Chris was talking about,umm Hang on a mo you aren't talking about the two fwd mounts that the roof sits on in the boot are you? now that would be funny!! Quote Link to comment Share on other sites More sharing options...
gaz1 Posted January 4, 2008 Share Posted January 4, 2008 maybe his chassis is still twisted:d ouch:blink: Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted January 4, 2008 Share Posted January 4, 2008 maybe his chassis is still twisted:d The chassis was NEVER twisted or touched in the first place and I can guarantee that all the work carried out is 100% and faultless. I also challenge anybody on here who can fault it. Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted January 4, 2008 Share Posted January 4, 2008 The following pertains to an apparent difference in design from the normal “coupe” hardtop supra to the aerotop; The interior bits are currently being swapped over from my coupe into the aerotop, however, the rear seats wont fit properly due to some additional catches or elements that Chris at hyper has said looks like there should be a form of strut bar (for example) running in between for strengthening (due to the aerotop?). This "addition" is found behind the rear seats but before the stock subwoofer (which is found in GZ's) I’ve asked Chris to take a picture to help explain things better, but in the meantime, does anyone know what I’m trying to describe here? What exactly are these two things, and should there be a bar running in-between them? Is it strengthening? And as such is it an essential part that needs replacing or are these two things just redundant? Thanks on advance Matt Chris, did contact me asking if there was supposed to be a part in the rear seat area, but I couldn't picture what he meant, I could do with pictures if he gets stuck. Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted January 4, 2008 Share Posted January 4, 2008 Hers's some pictures for you Matt. [img]http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4166.jpg[/img] [img]http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4167.jpg[/img] [img]http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4173.jpg[/img] [img]http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4175.jpg[/img] Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 9, 2008 Author Share Posted January 9, 2008 Chris, did contact me asking if there was supposed to be a part in the rear seat area, but I couldn't picture what he meant, I could do with pictures if he gets stuck. Hers's some pictures for you Matt. http://http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4166.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4169.jpg http://http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4167.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4171.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4172.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4170.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4174.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4176.jpg http://http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4173.jpg http://http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4175.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4178.jpg http://i140.photobucket.com/albums/r15/proboost/Misc%20Pics/100_4184.jpg Cheers Ibrar, There great Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 9, 2008 Author Share Posted January 9, 2008 Heres some pics of the bits im talking about: Definatly looks like strengthening, but should there be a bar coming accross from the first two pics?! Best pic is Ibrar's third pic in his last post Quote Link to comment Share on other sites More sharing options...
TrickTT Posted January 9, 2008 Share Posted January 9, 2008 Your first 2 pics show the bit that holds the mounts for the aero roof when it is in the boot, there is nothing bolted inbetween them. The third pic is a bolt on strengthening piece at the bottom of the B-post and is hidden behind the rear trim panel. You will probably need some aero trim panels to fit where the roof mounting bits are. I'll try and get some pics later from mine. Edit, here is a couple of shots with the seat in. The rear seat is the same in aero and hardtop, just the trim panels are different Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 9, 2008 Author Share Posted January 9, 2008 Your first 2 pics show the bit that holds the mounts for the aero roof when it is in the boot, there is nothing bolted inbetween them. The third pic is a bolt on strengthening piece at the bottom of the B-post and is hidden behind the rear trim panel. You will probably need some aero trim panels to fit where the roof mounting bits are. I'll try and get some pics later from mine. Edit, here is a couple of shots with the seat in. The rear seat is the same in aero and hardtop, just the trim panels are different http://i83.photobucket.com/albums/j320/trick152/100_0356.jpg http://i83.photobucket.com/albums/j320/trick152/100_0357.jpg Oh right, cheers mate, from Ibrars 11th pic, is that the different trim panel for the aerotop? ta Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted January 10, 2008 Share Posted January 10, 2008 Oh right, cheers mate, from Ibrars 11th pic, is that the different trim panel for the aerotop? ta Yes Quote Link to comment Share on other sites More sharing options...
