eyefi Posted July 5, 2002 Share Posted July 5, 2002 which is the o2 sensor and which is the cat temp sensor on and around the downpipe? cheers. Quote Link to comment Share on other sites More sharing options...
Steve W Posted July 5, 2002 Share Posted July 5, 2002 I think (but, wait for back-up) the upper/1st/top one is Oxy/Lambda, and the lower/2nd/bottom one is temp - ON A J'SPEC ! ! [ I believe, on a UK, they are BOTH Oxy/Lambda sensors ? } BUT, WAIT FOR THE 'BIG-BOYS' REPLIES ! ! Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 5, 2002 Share Posted July 5, 2002 Upper one is the O2 senser. The lower one is the CAT. You can also tell by the sensor component: CAT temp sensor is just a 1/4" rod O2 sensor is a lot thicker and ventilated And the wiring: CAT temp sensor has only one wire O2 sensor has four -Ian Quote Link to comment Share on other sites More sharing options...
eyefi Posted July 5, 2002 Author Share Posted July 5, 2002 cheers guys. i think ill give the oxy sensor a clean while im whipping the cats out, i think i run rich. lemon juice is supposed to be good? Quote Link to comment Share on other sites More sharing options...
