wilkorangerover Posted January 1, 2008 Share Posted January 1, 2008 hello guys just fitted some new 19"s to my supra (standard springs) and the back wheels are rubbing on the arches whats wrong?????? Quote Link to comment Share on other sites More sharing options...
jazz1 Posted January 1, 2008 Share Posted January 1, 2008 roll your arches if that dont work you need coilovers, mine stick out a little bit but i have no rubbing issues because i have coilovers and iv rolled the arches Quote Link to comment Share on other sites More sharing options...
Wez Posted January 1, 2008 Share Posted January 1, 2008 What size tires have you put on them and what offset are the wheels? Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 275/35/19 Quote Link to comment Share on other sites More sharing options...
jevansio Posted January 1, 2008 Share Posted January 1, 2008 Your wheels may not be the perfect offest, I ran 265's with loads of clearance, rolling or grinding the arches looks like the only solution without changing wheels Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 what about these?? http://cgi.ebay.co.uk/Spring-Assistors-TOYOTA-SUPRA-86-93-Towing-Suspension_W0QQitemZ110209534131QQihZ001QQcategoryZ33653QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1638.m118 Quote Link to comment Share on other sites More sharing options...
jazz1 Posted January 1, 2008 Share Posted January 1, 2008 just roll the arches not that much cost Quote Link to comment Share on other sites More sharing options...
Wez Posted January 1, 2008 Share Posted January 1, 2008 I use to run 275 on 17" rears without any rubbing issues, whats your wheel offsets? Quote Link to comment Share on other sites More sharing options...
jazz1 Posted January 1, 2008 Share Posted January 1, 2008 http://www.mkivsupra.net/vbb/showthread.php?t=93274 mine stick out of the arches i have no problems in rubbing as i have rolled my arches and have coilovers Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 they are rubbing the outside of the tyres Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 will these work?? http://cgi.ebay.co.uk/Spring-Assisto...sid=p1638.m118 Quote Link to comment Share on other sites More sharing options...
jazz1 Posted January 1, 2008 Share Posted January 1, 2008 http://www.archenemy.co.uk/ 70 pounds he will come to you and roll them Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 i live in chesterfield though, will them towing things do anything??? as i have some on another car i could borrow Quote Link to comment Share on other sites More sharing options...
Thorin Posted January 1, 2008 Share Posted January 1, 2008 On 19's *shudder* the tyre profile should be 30, not 35. Ultimately though if your wheels are the wrong offset then whatever profile you have you'll get rubbing. Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 they were new, and sold as supra wheels, from a shop Quote Link to comment Share on other sites More sharing options...
uk-rich Posted January 1, 2008 Share Posted January 1, 2008 What size tires have you put on them and what offset are the wheels? I use to run 275 on 17" rears without any rubbing issues, whats your wheel offsets? maybe due to offsets Quote Link to comment Share on other sites More sharing options...
Thorin Posted January 1, 2008 Share Posted January 1, 2008 they were new, and sold as supra wheels, from a shop That doesn't mean they're the right offset, but as I stated your tyre profile is too large which will certainly be contributing. Quote Link to comment Share on other sites More sharing options...
AJI Posted January 1, 2008 Share Posted January 1, 2008 as Thorin says... on 19" diametre the profile (to keep same rolling radius as stock tyres) should be 30 and not 35. Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 i think i`ll try the spring inserts for now, i`ll let you know how it goes tomorrow Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 1, 2008 Author Share Posted January 1, 2008 rears are 9.5 J 35 offset Quote Link to comment Share on other sites More sharing options...
gambie Posted January 2, 2008 Share Posted January 2, 2008 i have 275, 19" on mine and they don`t rub the fronts will catch the wheel arch plastic on hard lock on front sometimes Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 2, 2008 Author Share Posted January 2, 2008 could do with getting some adjustables, ..... Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted January 2, 2008 Author Share Posted January 2, 2008 do supras have bump stops on the suspension? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 3, 2008 Share Posted January 3, 2008 they were new, and sold as supra wheels, from a shop Find out from said shop, what the width and offset of the wheels is, if they are rubbing then the offset is likely to be too low. The wrong tyre size will also be making the problem worse. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 3, 2008 Share Posted January 3, 2008 do supras have bump stops on the suspension? yes Quote Link to comment Share on other sites More sharing options...
