Part numbers please
mwilkinson
Could someone with an EPC please provide me with the part numbers for the rubber seals (LH and RH) that go on each of the doors which when the window closes they seal against.
I have the picture from the EPC which only states 67861 (RH) and 67862 (LH).
Also is this the correct part number for the hood stay clip:
53452-14010 and the Seal, front fender to cowl side 53866-14030(these are the small bits of rubber that fill the gap at the base of the front pillar against the front wing).
Thanks in advance.
Thanks in advance.
These are correct.
I'm not 100% sure about the window seals, I don't want to give you the incorrect ones. I recall the part numbers being requested before so a search might give you what you need.
