flukey-lukey Posted December 28, 2007 Share Posted December 28, 2007 OK, can someone please enlighten me.... read this http://www.mkivsupra.net/vbb/showthread.php?t=117722&highlight=bride&page=2 then tell me which bride subframe will fit some factory recaro seats, direct bolt on to the supra floor with sliding action please Thankyou muchly, myself and Mr RobSheffield can't figure it out Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 28, 2007 Share Posted December 28, 2007 i am with rob on this one:D Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted December 28, 2007 Author Share Posted December 28, 2007 i am with rob on this one:D Bet you've been drinking haven't you? you always have a drink on the weekend I know these things y'see Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 28, 2007 Share Posted December 28, 2007 Bet you've been drinking haven't you? you always have a drink on the weekend I know these things y'see just doing my bit to help;) Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted December 28, 2007 Author Share Posted December 28, 2007 I've just been informed they are recaros from an EVO... does this make a difference?? I need answers!! lol Quote Link to comment Share on other sites More sharing options...
uzthedentist Posted December 29, 2007 Share Posted December 29, 2007 are they base mount or side mount Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 29, 2007 Share Posted December 29, 2007 Base - 6 allen bolts into the base of the seat Quote Link to comment Share on other sites More sharing options...
broomie Posted December 29, 2007 Share Posted December 29, 2007 ro if recaro speed Quote Link to comment Share on other sites More sharing options...
supradibbs Posted December 29, 2007 Share Posted December 29, 2007 i need to know too Quote Link to comment Share on other sites More sharing options...
uzthedentist Posted December 29, 2007 Share Posted December 29, 2007 this is what you need for base mount PART RO http://www.neweraparts.com/Default.aspx?tabid=54&CategoryID=159&List=0&catpageindex=3&Level=a&ProductID=238 Quote Link to comment Share on other sites More sharing options...
supradibbs Posted December 29, 2007 Share Posted December 29, 2007 this is what you need for base mount PART RO http://www.neweraparts.com/Default.aspx?tabid=54&CategoryID=159&List=0&catpageindex=3&Level=a&ProductID=238 and they will fit the recero speed seat correct and do you need ro for both sides and just select supra from the drop down? Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted December 30, 2007 Share Posted December 30, 2007 Ive been told to get the 'MO' Type with Recaro Speed Those were the only one's i could find on 'newera' that listed a Supra Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted December 30, 2007 Author Share Posted December 30, 2007 Thanks for the input guys! Still a little confused though, RO or MO? Quote Link to comment Share on other sites More sharing options...
supradibbs Posted December 30, 2007 Share Posted December 30, 2007 Ditto Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 30, 2007 Share Posted December 30, 2007 Thanks for the input guys! Still a little confused though, RO or MO? Since it IS base mount id go with what Uz says - RO Quote Link to comment Share on other sites More sharing options...
uzthedentist Posted December 30, 2007 Share Posted December 30, 2007 ill fire off an email to confirm, can anyone give me the dimensions of the bolts so i can see if theyre the same as brix 1 or 2 Quote Link to comment Share on other sites More sharing options...
uzthedentist Posted December 30, 2007 Share Posted December 30, 2007 im pretty sure its RO type as MO fits brix 1 but the speed had brix 2 spaced bolt holes (RO-type) appears to match the dimensions of the Recaro.The Recaro sppeds width is 405mm and the distance from the rear to front holes are 235 and 260 mm respectively. Check out the pic below and you'll see that they appear to match. http://www.tees-usa.com/images/rail_s_RO.gif but ill confirm 100% whn i get a mail back mo are completely different http://www.tees-usa.com/images/rail_s_MO.gif Quote Link to comment Share on other sites More sharing options...
supradibbs Posted December 30, 2007 Share Posted December 30, 2007 yeah i would say its ro Quote Link to comment Share on other sites More sharing options...
MrHanky Posted December 30, 2007 Share Posted December 30, 2007 The only difference between RO's, MO's and FO's are the mounts. The RO's do not have mounts and thus the seats just fit directly to the rails. The MO and FO rail sets come with base or side mounts respectively. Go for the MO's or FO's as then you will also get the mounts, should you ever want to change seats. I think this is correct anyway. I spent a lot of time reading all about the different ones when I had issues with mine. Below is one of many emails sent to Nengun after they sent me side mounts instead of base mounts. "I have just been researching this via various sites which show the dimensions of the rails and part numbers. MO's definately work for the Supra and seats that I have. In fact the only difference between the FO and MO rails for the Supra are the actual mounts for the different type of seats. See attached word document. Looking at the actual rails supplied to me and comparing them to the ones on the Tee's site T109 and T110 rails are used for FO's, RO's and MO's. The only reason they use the code T109FO etc is because that is the kit code to make sure that they ship the side mounts with the actual T109 rail. This obviously makes sense from a manufacturing point of view as you can then just send the relevant mounts with the actual rail and save yourself producing 3 different types of rails. "Rails[1].doc Quote Link to comment Share on other sites More sharing options...
uzthedentist Posted December 30, 2007 Share Posted December 30, 2007 mate the mo is basically a ro with 2 extra bits so it can fit other base mounts im 99% sure you need ro for recaro speeds but i will confirm FO for side mounts only, nothing to do with the speeds Quote Link to comment Share on other sites More sharing options...
MrHanky Posted December 30, 2007 Share Posted December 30, 2007 mate the mo is basically a ro with 2 extra bits so it can fit other base mounts im 99% sure you need ro for recaro speeds but i will confirm FO for side mounts only, nothing to do with the speeds Thats what I said above, just in a lot more words I would go for the MO's as they cost about £7 more (when I look at the 2 types on Nengun.com) and you can use them in future for other seats. Mark Quote Link to comment Share on other sites More sharing options...
mr keef Posted December 30, 2007 Share Posted December 30, 2007 i got mine from Paul Whiffin:) Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted December 30, 2007 Share Posted December 30, 2007 Or wait untill mine get here, and i'll tell you Quote Link to comment Share on other sites More sharing options...
lockys96 Posted December 30, 2007 Share Posted December 30, 2007 i would also say its RO-Type. when i had my glanza, i fitted stock mk6 mitsi evo seats in it. i imported recaro frames to fit via japan they looked exactly like that, not like the the MO Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted December 30, 2007 Share Posted December 30, 2007 So ive just spent £300 on the wrong ones?! Could easily modify though Quote Link to comment Share on other sites More sharing options...
