Wez Posted January 15, 2009 Author Share Posted January 15, 2009 A Land Rover Disco TD5 is another option, it will also need to be my daily driver. Link to comment Share on other sites More sharing options...
dangerous brain Posted January 15, 2009 Share Posted January 15, 2009 Go for as new a disco as you can get. My rec would be an LPG V8 if you can find one. Link to comment Share on other sites More sharing options...
JamieP Posted January 15, 2009 Share Posted January 15, 2009 Mitsubishi L200 pickups can be had for that money, will tow with ease and plenty of room in the back for spare wheel/parts etc, avoid the early D22 navara, they have big engine problems. Link to comment Share on other sites More sharing options...
lockys96 Posted January 15, 2009 Share Posted January 15, 2009 pajero evo, lol Link to comment Share on other sites More sharing options...
ozz Posted January 15, 2009 Share Posted January 15, 2009 If you go for the disco, make sure its a facelift 2002/3 onwards, most of the car was changed and its a much better ride. Mine cost £5150 for a 52 plate last month, Td5 with the 3.5t limit. Massive improvement on the older models, the air suspension is cool but expensive if it goes wrong. Link to comment Share on other sites More sharing options...
Vicky Posted January 15, 2009 Share Posted January 15, 2009 The mitsubishi shogun warriors are also very good at towing and are a comfortable every day car too. Link to comment Share on other sites More sharing options...
colsoop Posted January 15, 2009 Share Posted January 15, 2009 I would go with a landcruiser, solid bit of kit. Link to comment Share on other sites More sharing options...
merckx Posted January 15, 2009 Share Posted January 15, 2009 I have been using the parkers online guide to see what the towing weights are, the 530d comes in at 2000kg which should cover a stripped out MKIV on a trailer. That's a very high towing weight for a 530. Manufacturers towing limits are not set by issues of stability, simply by the car’s physical capability. In an ideal world, with perfectly surfaced roads, no crosswinds, air turbulence from speeding HGVs etc, then this limit could be used for matching purposes. It's widely recommended that you shouldn't tow anything heavier than 85% of the kerb weight of the towing vehicle. Link to comment Share on other sites More sharing options...
Wez Posted January 15, 2009 Author Share Posted January 15, 2009 What do people think a twin axle trailer and a MKIV weighs in at? Is 2000kg a fair guess? Link to comment Share on other sites More sharing options...
TLicense Posted January 15, 2009 Share Posted January 15, 2009 Mitsubishi L200 pickups can be had for that money, will tow with ease and plenty of room in the back for spare wheel/parts etc, avoid the early D22 navara, they have big engine problems. The 200's are pretty thirsty though even when not towing anything. Link to comment Share on other sites More sharing options...
TLicense Posted January 15, 2009 Share Posted January 15, 2009 What do people think a twin axle trailer and a MKIV weighs in at? Is 2000kg a fair guess? It's going to be around that. Factor in a bit of additional weight for bits and bobs and a bit of a safety factor and you could be looking at as much as 2200Kg maybe. Link to comment Share on other sites More sharing options...
JamieP Posted January 15, 2009 Share Posted January 15, 2009 The 200's are pretty thirsty though even when not towing anything. For a diesel they are not great, my last L200 averaged 25mpg and my new Navara is only a little better. Link to comment Share on other sites More sharing options...
garethr Posted January 15, 2009 Share Posted January 15, 2009 I don't think I'd want to tow a car, even a stripped one, with a car... This was a Stagea towing a GTR. http://www.gtr.co.uk/forum/102648-r-i-p-s-drag-r-accident.html Link to comment Share on other sites More sharing options...
Wez Posted January 15, 2009 Author Share Posted January 15, 2009 Maybe a TD5 or shogan then, as its going to be used every day I dont want crazy MPG Link to comment Share on other sites More sharing options...
JamieP Posted January 15, 2009 Share Posted January 15, 2009 I don't think I'd want to tow a car, even a stripped one, with a car... This was a Stagea towing a GTR. http://www.gtr.co.uk/forum/102648-r-i-p-s-drag-r-accident.html Blimey, stuff towing with a car, get something heavy like a landcruiser mate. Link to comment Share on other sites More sharing options...
baz Posted January 15, 2009 Share Posted January 15, 2009 ive got a pajero 2.8td for sale. drop me a line if your intrested Link to comment Share on other sites More sharing options...
dangerous brain Posted January 15, 2009 Share Posted January 15, 2009 If you go for the disco, make sure its a facelift 2002/3 onwards, most of the car was changed and its a much better ride. Mine cost £5150 for a 52 plate last month, Td5 with the 3.5t limit. Massive improvement on the older models, the air suspension is cool but expensive if it goes wrong. Ah you can pull that air suspension straight out for not a lot of money. AFAIK its only the rear of that model is on air right?? Its only a case of swapping out the airspirings for coil springs. Did it on my rangey all round for £450. Link to comment Share on other sites More sharing options...
Wez Posted January 15, 2009 Author Share Posted January 15, 2009 If you go for the disco, make sure its a facelift 2002/3 onwards, most of the car was changed and its a much better ride. Mine cost £5150 for a 52 plate last month, Td5 with the 3.5t limit. Massive improvement on the older models, the air suspension is cool but expensive if it goes wrong. Wont the 2002 onwards have higher road tax? Link to comment Share on other sites More sharing options...
dangerous brain Posted January 15, 2009 Share Posted January 15, 2009 Thats a downside alright Link to comment Share on other sites More sharing options...
Wez Posted January 15, 2009 Author Share Posted January 15, 2009 So an early 2001 TD5 sounds like a good option or possibly something jap. Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2009 Share Posted January 15, 2009 Blimey, stuff towing with a car, get something heavy like a landcruiser mate. cheques in the post Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2009 Share Posted January 15, 2009 I would go with a landcruiser, solid bit of kit. How much do you want Link to comment Share on other sites More sharing options...
sidewaysdan Posted January 15, 2009 Share Posted January 15, 2009 ive got a 1998 mercedes vito 2.3 petrol 7 seater 82k fmsh full leather gets about 400mls to £70.on a long run. i towed my quad to ibiza and back great motor. 4k Link to comment Share on other sites More sharing options...
Homer Posted January 15, 2009 Share Posted January 15, 2009 IME towing 2000kg+ in a car is really not a nice experience, a big and heavy 4x4 is a far easier and safer way to pull something of that weight. Range rovers are superb for it, but obviously expensive to run. I had a landcruiser diesel for one jouney and that felt the safest other than the range rover. You could pick up an older diesel range rover for not too much these days, they are VERY comfy, have lots of toys but fuel economy is bad. Link to comment Share on other sites More sharing options...
dangerous brain Posted January 15, 2009 Share Posted January 15, 2009 I'd soooo stay away from a p38 range rover deisel. Not only does it have the unreliability issues that are inherent in p38's its also not got the oomphy feeling from the V8 and is in fact slower than a snail. DNK's landcruiser is what I'd look at. Link to comment Share on other sites More sharing options...
