Tyre Pressure
KimberleyAnn
surely 34psi 'pounds per square inch' would be the same in any size wheel or tyre, as its per inch, doesn't matter how many inches of air there is in the tyre :)
The bigger the tyre the more pressure required for it to keep its profile correct.:)
The 16's on 245's from my last moment only ever needed 32 and 30 psi.
it's not a hard fast rule, weight and power come into it.
Golden rule is to keep checking the wear on the tyres to see if it's even. :)
