The best Source for Water Cooled Turbo?
bolarbag
Where is the best source for your water for a water cooled turbo, was thinking just blank off the oem sources on the top water elbow and replace with a 6an fitting?
Im not 100% up on the water cooled turbos as mine is only oil cooled, but i believe you use a stock feed off the water pump and use the top elbow as a return into the cooling system.
