Location of restrictor ring
ROCKETMAN
Hi All,
I have a 'Whifbitz' double de-cat with restrictor ring fitted on my 93 TT Jspec. Can anyone tell me where the restrictor ring is located i.e. between which parts of the exhaust? Just asking as I may have to fit my cat for an MOT and want to make sure the garage understands which parts are fitted where.
Sorry if that is a lengthy, verbose explanation. Still brain dead from Christmas!:blink:
Cheers.
Does it matter? I thought it could go anywhere along the exhaust system. I have mine between the back box section of the nur spec R and the rest of it that goes upto the second cat. It is the easiest place to get to so it went in there :) It holds boost back fine. However I think the most common place is between the second de-cat pipe and the rest of the exhaust.
