Locking Nuts Problem
Adam Kindness
Righto-
I seemed to forget to pick up my locking nut (key thing socket) at the track last sunday!!
Any ideas on how to remove the nut!
Its a nut with a hollowed out centre and square grooves round the edge!
I phonned the place i got them from... they were no help... telling me that the company didnt sell replacements!!! ( abit shocking if you ask me)
They suggested hammering a socket over them or buying nome sort of 'skeleton key' nut type thing... It has pins that move etc... so it'l adjust to the shape of the locking nut!
But i cant remember the name of it! started witha G!!!?!?!?!
please help!!! i need it by sat morning!
Doesn't this show how useless some locking nuts are if the thief has an old socket and a hammer. I helped out a TVR owner a couple of years ago at the Brighton Speed Trials who'd had his locking nut key nicked and had a set of slicks on the rear when it came to time to drive home! It took a minute to figure it out from scratch but an old socket & hammer did the trick.
Yes, it is GAITOR Steve, although there are now loads of copies/others. :thumbs:
BUT, the're not really as strong as a 'right-size' socket/spanner.
some of the cheaper ones don't use hardened pins (the moving bits
which 'adjust') :mad:
As we said in someone elses thread, the 'real' answer was the
nut-remover 'sockets' which are a bit like stud-removers, they
tighten onto the nut with a reverse thread as you undo.
BUT, HAMMERED-ON ORDINARY SOCKET will work, if they haven't
been done up properly/too tight. :thumbs:
