Squiffy handling
Ian C
Well, nothing too bad but I get stressed if things aren't 100%.
Under braking the car is nervous - want's to pull left and right. The braking performance seems less than optimal at times as well.
The car also feels like it's tramlining more than usual as well, maybe a bit of wandering.
Now, the factors that may influence this are:
I have been running, inadvertantly, 18psi or so in the front right tyre for a few hundred miles. The valve cap is dodgy, the rubber seal has come adrift and can press on the valve stem a bit. I'll be replacing that on Saturday.
I've pumped this tyre back up, and the handling is still iffy. I know from experience that a change in pressure over extended mileage can wear the tyre into a new road profile. When pumped back up, it can feel exactly as mine does now, but after a few hundred miles of feeling nervous and wandering they seem to recover the normal handling.
I intend on getting the tracking checked out on Saturday as well.
The car doesn't do too many miles, especially with the troubles I've been having, so it spends a lot of time standing in the garage. This may have implications.
The brake pedal also seems to have a too-long travel and be lacking feel. Time for a brake fluid change, perhaps?
Anything else I should check?
Basically, I stress when there is something out of true with the car and I hate not being able to get on and diagnose/sort it right away (I'm at work - grrr), so this post is an effort to pacify my daemons :D
-Ian
(edited to tidy up an apallingly ambiguous paragraph)
Hi Ian
Have you been doing any suspension work? I had a poorly installed shock absorber, which caused meanderings. Other than that, pretty much what you said - pressures, alignments, or play in steering bushes etc.
It could be a warpped disc, mine is a j-spec and just been diagnosed with this. I had the same symptoms, as you have described.
The garage is skimming the disc's for me as we speak, and has assured me it will correct the problem.
rgds,
Marcus
