What can cause a car too backfire????
supradriver
I know someone with a Mitsubishi FTO its got the ECU chipped and K&N air filter.
The car has had a service not long ago and had the cam belt changed now its starting to backfire, what can cause this?????
Thanks ….
Plugs, bad timing etc.
Gun powder in the tank. ;)
  • 2 weeks later...
I think if it you can make it backfire by flooring it then suddenly lifting off its more likely to be an exhaust leak as its sucking in air. I know that Porsche 911's and aircooled Vdubs suffer this from the slightest exhaust leak causing a popping burbling on the overrun and the odd bang mixed in.
