How much transmission fluid is in the radiator?
DamanC
Swapping my radiator out tomorrow for a Golpher ali jobbie that like the stocker has a transmission cooler built in. Im guessing its going to be of similar volume to the stocker but I have no idea how much this isso I dont know how much to buy :(
Any ideas guys?
is the stock cooler not a fan?? yours is a j-spec is'nt it Damon?
if its a full on flush, ie torque converter and all then I would get 12ish litres (seriously) :blink:
Just a top up from what I will lose when swapping the radiator out. It is a J spec :)
I dont know what the stock cooler is :blink: im guessing its an area set aside withing the rad where the fluid resides? My radiator had one larger fan mounted in front of the radiator (passenger side) but that went in the bin when I put my fmic on, I believed it to be the air con cooler? From what I understand there is a smaller fan mounted to the radiator shroud on the back of the radiator which I *think* blows/sucks air to cool the transmission.....
Im sure someone with more tech know how than me will confirm that...
