window adjustment?
ballsdeep
The bracket in the middle at the bottom there with two white plastic parts underneath it is how to adjust the windows angle to the car. it adjusts the top of the window in towards the car or out away from it. There are two bump stops that stop the window going any further upwards that can be adjusted. Watch the window going up and you will see where the bump stops contact with the window mounting mechanism. Also I am going from memory here but the window glass is attached to the mechanism that pushes it up and down (sorry I can't remember how many bolts I think 3 though) When you loosen these the window will be moveable forwards and backwards and you can independently lift the front edge of the glass and back end of the glass before you tighten the bolts back up. If you post a clearer image I can maybe remember it better it is after all over two years since I did it.
cheers pal sounds very helpful.. will try n get some more pics up in the morning!! ;)
