Greddy Profec B Spec II Boost Controller
Ryan.G
Greddy Profec B Spec II Boost Controller in Silver complete with Solenoid, wiring and instuctions.
Can be used with Ext and Int wastegates
Displays current boost pressure, Peak and enables the user to set warnings.
Probably my favourite Boost controller also as easy to setup and fit
Ryan
SOLD
Ryan
hmmmm would this help my setup mate?
Andy you have too much money to spend on cars. Spend the money on some R888 for the summer to help with traction :D
In answer to your Question, No it wouldn't lol
Yours is setup to control the boost through the ecu which is better as is setup against TPS, RPM and What ever you adjust it to on the Volume knob.
This is just a boost controller for people with Standard ecu's or Ecu which can not control the boost
You also have a limit set which is done on the ecu to cut Ignition when ever 1.48bar is hit.
  • 3 weeks later...
