MONKEYmark Posted January 3, 2005 Share Posted January 3, 2005 hi just tried to try edit drag racing post and there is no edit button. has the option been turned off? did a search on FAQ and came up with below If you have registered, you will be able to edit and delete your posts. Note that the administrator can disable this ability as he desires. Your ability to edit your posts may also be time-limited, depending on how the administrator has set up the forum. To edit or delete your posts, click the button by the post you want to edit. If your post was the first in the thread, then deleting the post may result in the removal of the entire thread. After you have made your modifications, a note may appear, which notifies other users that you have edited your post. Administrators and moderators may also edit your messages but this note may not appear when they do so. Link to comment Share on other sites More sharing options...
mawby Posted January 3, 2005 Share Posted January 3, 2005 I meant to change the time limit on being able to edit posts before the "This was edited by" appears at the bottom, but instead I changed the actual time limit on editing posts! Sorted now. Link to comment Share on other sites More sharing options...
MONKEYmark Posted January 4, 2005 Author Share Posted January 4, 2005 thanks for that Link to comment Share on other sites More sharing options...
