adi2009 Posted December 18, 2007 Share Posted December 18, 2007 Hi everyone, would it be possible to use the TT supra's coil packs on the 2JZ-GE engine and convert it to a coil on plug ignition system if one were to use a standalone engine management system such as the Autronic SM4??? Any help would be great Cheers adi Quote Link to comment Share on other sites More sharing options...
JustGav Posted December 18, 2007 Share Posted December 18, 2007 There is a possible way using an emanage ultimate, not sure if anybody has used the option yet. Quote Link to comment Share on other sites More sharing options...
bromy Posted December 18, 2007 Share Posted December 18, 2007 Dave Henry is your man for this (DaveH) over on either club na-t or supraforums. You use the CPS from a mk3 supra etc, the wiring is a bit complicated but ask him over on there Quote Link to comment Share on other sites More sharing options...
Guest cascam330 Posted April 17, 2015 Share Posted April 17, 2015 Hi everyone, would it be possible to use the TT supra's coil packs on the 2JZ-GE engine and convert it to a coil on plug ignition system if one were to use a standalone engine management system such as the Autronic SM4??? Any help would be great Cheers adi hi adi2009. im also from india. im planning to do distributor to coil pack conversion? whats your suggestion? whats easily available in our country or import asusual? Quote Link to comment Share on other sites More sharing options...
Style Posted April 17, 2015 Share Posted April 17, 2015 http://www.mkivsupra.net/vbb/group.php?groupid=62 Quote Link to comment Share on other sites More sharing options...
David P Posted April 17, 2015 Share Posted April 17, 2015 Even Group members forget about the Group? Linked these threads. http://www.mkivsupra.net/vbb/showthread.php?321399-Distributor-delete-(COP)-parts-list Quote Link to comment Share on other sites More sharing options...
Noz Posted April 17, 2015 Share Posted April 17, 2015 Even Group members forget about the Group? Linked these threads. http://www.mkivsupra.net/vbb/showthread.php?321399-Distributor-delete-(COP)-parts-list Doesn't solve the ECU problem if you're not stand alone. There needs to be a wiring diagram for this too, all the one's I've found aren't totally complete. Quote Link to comment Share on other sites More sharing options...
David P Posted April 17, 2015 Share Posted April 17, 2015 The T.T. ECU does the trick a treat. The OE Workshop Manual wiring diagram is all that is needed. Quote Link to comment Share on other sites More sharing options...
Guest cascam330 Posted April 18, 2015 Share Posted April 18, 2015 i ve a standalone aem ecu for the supra. will it be a problem? NA-T done. Quote Link to comment Share on other sites More sharing options...
David P Posted April 18, 2015 Share Posted April 18, 2015 Read the information in the Group link. Quote Link to comment Share on other sites More sharing options...
