oil warning lights
Guest big ste
Guest big ste
okay im thinking you have all been asked this before so i apologise now.on the right hand side of the dash there is a red oil warning light and yellow,what is the difference between them?
cheers
ste :blink:
Trouble is, whether it's a buzzer or light it's likely to be a bit late to save damage if it's triggered by the factory switch (assumes the factory switch is 5-7psi?).
Very true, but for the sake of a £1 buzzer, it is a better warning at least especially since the stock lights have this dry joint issue.
All my units on the dash were replaced not long ago :D but my oil level warning light has flickerd up a feew times this past week. but goes off after i second or so.
Is the oil level okay? The light will sometimes come on going up or down a hill if it is low.
You can get electronic oil pressure gauge that has both audible and visual warning they are usually preset at 15 or 18PSI,or you can buy the pressure sensor for the Blitz I-color, so you can set your own warning :) also its easy to fit a super bright LED to the oil level warning light, to make sure you notice, saved my engine when i had a FMS problem;)
  • 3 weeks later...
:) Thanks Rick. Will get that fitted.
