Any Skyline Techies?
DannoSupra
I got a question for the techies!
My mates' got an R33 GTR (1995) coverd 27k (import)
The previous owner claims its got 330-350hp. All its got is aftermarket Air Filters and a Cat Back Exhaust
Now, the problem:
It’ll drive ok under load, as normal. But on cruise speed, really light throttle, it hesites/misfires/splutters, and sometimes turbo lag. But as soon as you give it throttle, it’ll start to spool up and she’s going fine again!
It's had the plugs, oil+filter and 3 aux belts changes. We also found a bust spring in one of the coil packs, so replaced that.
Is it possible that the sumptoms are leading towards a Inlet Manifold Gasket Failure?!
Cheers
Guest civicsam
hey danno, older skylines suffer pretty badly from coil faliures, ive replaced 2 sets, on 2 skylines we've imported this year. so possibly could be that.
It runs a 2 three cylinder engines, each 3 cylinders under closed loop from their own oxygen sensor, and air flow meter. The 3 most likely problems are air flow meter dad or dying, an O2 sensor dead, or a turbo on its way out. get it on a Nissan Consult diagnostic reader, or measure the voltage at the ecu from each of the AFM's and scope the O2 sensor outputs. If both check out ok do a vac check, and get the compressions and leakdowns checked, then suspect a turbo. AFM or O2 sensor are the most likely culprits, I'd say O2 sensor as a guess.
