Sisky Posted December 13, 2007 Share Posted December 13, 2007 have the supra 2 months now and i need to overcome my crippling laziness and get some elbow grease and a good polish and get buffing the paintwork to get rid of some of the streaking and scratches.... anyone had some good success with some product here on the white that they would recommend??? Cheers, Seán Link to comment Share on other sites More sharing options...
Guest mk47 Posted December 13, 2007 Share Posted December 13, 2007 Not sure of white but the meguiars 3 step system is easy to use and usually gives good results. some plastx on the headlamps also work a treat Link to comment Share on other sites More sharing options...
Daston Posted December 13, 2007 Share Posted December 13, 2007 Dodo juice Diamond white http://www.thepolishingcompany.com/dodoproductrange.html Link to comment Share on other sites More sharing options...
TonyP Posted December 13, 2007 Share Posted December 13, 2007 Not sure of white but the meguiars 3 step system is easy to use and usually gives good results. some plastx on the headlamps also work a treat I use the Meguiars three step on my white supe. Lot of work but well worth the effort. Oh and clay bar it first. Link to comment Share on other sites More sharing options...
Sisky Posted December 14, 2007 Author Share Posted December 14, 2007 I use the Meguiars three step on my white supe. Lot of work but well worth the effort. Oh and clay bar it first. clay bar it ??? Link to comment Share on other sites More sharing options...
Konrad Posted December 14, 2007 Share Posted December 14, 2007 Yes, use clay bar before polishing. I would say G3 will do for polishing, but it is a LOT of elbow grease involved if you do not use any polishing machine like Porter Cable for example. Link to comment Share on other sites More sharing options...
TonyP Posted December 14, 2007 Share Posted December 14, 2007 clay bar it ??? Meguiars Clay Kit Comes with spray used as a lubricant and a clay bar which you rub over the surface of the car. It removes all dirt and contaminants on the paint. Do it after washing but before polishing. You won't believe the difference it makes. Link to comment Share on other sites More sharing options...
Sisky Posted December 14, 2007 Author Share Posted December 14, 2007 cheers Link to comment Share on other sites More sharing options...
wile e coyote Posted December 14, 2007 Share Posted December 14, 2007 I have used the Meguiars on my white on and looks great Link to comment Share on other sites More sharing options...
IDO Posted December 14, 2007 Share Posted December 14, 2007 Meguiars Clay Kit Comes with spray used as a lubricant and a clay bar which you rub over the surface of the car. It removes all dirt and contaminants on the paint. Do it after washing but before polishing. You won't believe the difference it makes. yep I agree with the above My white looks good after the clay and meguiars 3 step, very happy with it.. To be honest i haven't tried anything else as the result is so good. Link to comment Share on other sites More sharing options...
