quick question on wheels
Adam Kindness
STD 16" J-Spec 5 spokes... what offset are they?
Are they the same front/rear?
is PCD 114.3 ??
I looked through search but could only find offset info for clearing UK brakes :)
REASON _ my mate wants a set of track/ 1/4mile spares... i said he could try mt old fronts on for size... but were trying to find out compatability first!
scoob is 50'ish mm offset i think
I thought Toyota went to 17's so that they could use the larger
diameter brake rotors etc ? ?
It might not JUST be offset you need to worry about but
diameter clearance as well ?
ie. don't think 16's will clear SIZE of UK/bigger brakes !
(hope I'm wrong 'cos I've got the 16's)
{ I KNOW the mounting holes are the same though = PCD }
it should say on the wheel. on the 17's its cast on the outside of the wheel.
im sure the offset will b the same on the 16's as 17's, but i could b wrong.
offset wont make much difference on the 1/4 but will on a track.
yr right about PCD.
basically, no. if he wants a cheap 2nd set of wheels to drag he will b able to buy any set of wheels that will fit his current config for the cost and hassle involved.
is there no stock scooby wheels for sale of their bbs. i dont think ive seen a scooby with stock wheels! someone must have a garage full.
