Been busy doing the LSD
edinlexusV8
 Share
Hi guys,
Been doing some work on my diff to swap the centre with a torsen LSD from a supra. I put up this thread to update you all about this and possibly get some advice if I get stuck. But I am stuck at step 14 SA100 - 14. Check Minimum Backlash. Any advice would be very much appreciated!
Started off by pulling the diff out. The one highlighted in yellow is the one I bought for this conversion. It is a post 1997 Supra TT diff centre which is 8" (same as the soarer diff centre). As I will be using the same crown wheel and the pinion, the teeth being 47 and 12 respectively the final gear ratio would remain the same as 47/12 = 3.917
 Share
