DIY 5 x 60mm gauge install
jevansio
Just thought I'd put up a pic of my custom gauge install (work in progress). I've decided to go with a full defi setup, I origionally wanted to put all 6 where the stereo is, but space is tight so 5 are going there & the boost will go on the a-pillar (along with the Innovate O2 gauge).
Going to get some fibreglass/filler stuff & spray tomorrow so hopefully the job will be completed at the weekend. The fibreglass & filler will be used to blend the joins between the origional dash & the new frame, it will then be sprayed origional grey and each hole will hopefully look like the ones where the clock etc are i.e. totally oem look.
Haven't decided what to do about the stereo yet, I may not even fit one if when I get the car back after going single the noise of the engine is music enough :D
