Jezz Posted March 29, 2007 Share Posted March 29, 2007 Anyone ever heard of a supra with GT4 st205 Brakes on? Just happened to notice they have the 4 pot fronts and 2 pot rears, so I test fitted them to a UK supra and they fit! Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted March 29, 2007 Share Posted March 29, 2007 The pads are the same too, but the discs are different. Gaz. Quote Link to comment Share on other sites More sharing options...
grahamc Posted March 29, 2007 Share Posted March 29, 2007 Anyone ever heard of a supra with GT4 st205 Brakes on? Just happened to notice they have the 4 pot fronts and 2 pot rears, so I test fitted them to a UK supra and they fit! dont suppose you know how well they work? Quote Link to comment Share on other sites More sharing options...
Kranz Posted March 29, 2007 Share Posted March 29, 2007 So they're exactly the same as Uk spec calipers???? Quote Link to comment Share on other sites More sharing options...
Jezz Posted March 29, 2007 Author Share Posted March 29, 2007 The pads are the same too, but the discs are different. Gaz. You mean the Celica discs Gaz? Pcd is different but AFAIK they were the same size as UK's? So if i purchased a set of UK discs from your good selves, i'd have a set of Uk brakes that say 'celica' on the calipers? Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted March 29, 2007 Share Posted March 29, 2007 Anyone ever heard of a supra with GT4 st205 Brakes on? Just happened to notice they have the 4 pot fronts and 2 pot rears, so I test fitted them to a UK supra and they fit! I had the same thought today jez - the celica gt4 calipers look very very similar to the supra uk ones have you tested them yet to see if theyre any good on a supe? Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted March 29, 2007 Share Posted March 29, 2007 You mean the Celica discs Gaz? Pcd is different but AFAIK they were the same size as UK's? So if i purchased a set of UK discs from your good selves, i'd have a set of Uk brakes that say 'celica' on the calipers? Yep, bascially Gaz. Quote Link to comment Share on other sites More sharing options...
Jezz Posted March 29, 2007 Author Share Posted March 29, 2007 I had the same thought today jez - the celica gt4 calipers look very very similar to the supra uk ones have you tested them yet to see if theyre any good on a supe? Ya. Fit perfectly, mounts exactly the same, just says Celica on the caliper, so i'll be getting the grinder out. Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted March 29, 2007 Share Posted March 29, 2007 Hmm, hold your horses mate!!! I tried this ages ago - putting st205 callipers (picked them up for £150) onto my J-spec Supe and they definitely DID NOT FIT!! I'm fairly sure that the top hat dimensions (the depth of the mounting bell) is different, therefore the callipers will not line up and the mounting holes, although lining up, are threaded as they fit on the opposite side of the lugs (outside the lugs rather than in front of - or vice versa). Quote Link to comment Share on other sites More sharing options...
tDR Posted March 29, 2007 Share Posted March 29, 2007 Yeah, I was thinking we already had a similar conversation which ended in evidence to say they wouldn't fit. IIRC ST205 GT4 discs are 315mm rather than UK spec 323mm discs. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted March 29, 2007 Share Posted March 29, 2007 I'll try to find my old post about it Here it is http://www.mkivsupra.net/vbb/showthread.php?t=64419&highlight=gt4 Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 29, 2007 Share Posted March 29, 2007 Another possible source for 4 pot calipers was one of the lexus, scXX (4x4 ?) something like that anyway i think , somebody mentioned it before. Quote Link to comment Share on other sites More sharing options...
Jezz Posted March 29, 2007 Author Share Posted March 29, 2007 Hmm, hold your horses mate!!! I tried this ages ago - putting st205 callipers (picked them up for £150) onto my J-spec Supe and they definitely DID NOT FIT!! I'm fairly sure that the top hat dimensions (the depth of the mounting bell) is different, therefore the callipers will not line up and the mounting holes, although lining up, are threaded as they fit on the opposite side of the lugs (outside the lugs rather than in front of - or vice versa). Strange. I actually had these bolted on! Dont know what your issues were Chris?! The bolts lined up perfectly, as did the caliper in relation to the disc. Yeah, I was thinking we already had a similar conversation which ended in evidence to say they wouldn't fit. IIRC ST205 GT4 discs are 315mm rather than UK spec 323mm discs. Cheers, Brian. Thats the only thing i need to check. The car i mounted them to earlier is j-spec, and you can see from the pic i posted a while ago the disc is slightly too small (j-spec). Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted March 29, 2007 Share Posted March 29, 2007 Jez, your pic shows 2-pot callipers - not 4s!! (unless there is a funny angle-thing going on??) Quote Link to comment Share on other sites More sharing options...
Jezz Posted March 29, 2007 Author Share Posted March 29, 2007 Jez, your pic shows 2-pot callipers - not 4s!! (unless there is a funny angle-thing going on??) Thats the rears mate. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted March 30, 2007 Share Posted March 30, 2007 Another possible source for 4 pot calipers was one of the lexus, scXX (4x4 ?) something like that anyway i think , somebody mentioned it before. Lexus LS has 4 pot calipers from 95 onwards... I had these on my Aristo. Gaz. Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 30, 2007 Share Posted March 30, 2007 Lexus LS has 4 pot calipers from 95 onwards... I had these on my Aristo. Gaz. Thank you, i thought i might have imagined it Quote Link to comment Share on other sites More sharing options...
supRo Posted March 30, 2007 Share Posted March 30, 2007 I think the LS400 has them as standard? Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted March 30, 2007 Share Posted March 30, 2007 I think the LS400 has them as standard? Hi Ro, Its does yep, after 95 - I put the calipers from an LS400 onto my GS300 Aristo. Gaz. Quote Link to comment Share on other sites More sharing options...
