Greddy BCC installation...
styggen82
  • 6 months later...
Guest KILLERMRS
Did it work?
I have the same problem, but the Pinouts dont help realy.
Does andybody know which one to cut for the Turbo Pressure Sensor?
Thank you
just use a multi-meter, and find the wire from the sensor on the manifold. trace it to the ecu, cut and install, tune it and boooooost:)
it`s the center wire on the sensor,
mine works perfect and I used the guide on mkiv.com, set it to 4,05 volt
  • 2 months later...
:D
When you guys say TPS - do you mean Throttle Position Sensor or Turbo pressure Sensor?
I am struggling to find the correct wire myself. I can't see any yellow/brown wires in the guide, could it be either the yellow red or yellow blue?
  halllon said:
:D
http://www.mkiv.com/techarticles/bcc/why_bcc/tps.jpg
wire nr 2 of the three that comes out of the turbo pressure sensor
  • 2 years later...
Guest littlez
hi there, i have a 98 vvti jpec and having troubles installing the BCC. I found the middle wire in the TPS its (black yellow for me)and installed the bcc like it says in the guide but now i have a malfunction and master warning lights going crazy on the dashboard.
Can enyone help me please?
Thank you
