Asked Getrag about the V160 replacement. This is what they told me. (look inside)
Guest Damien89
Guest Damien89
A couple of days ago i emailed getrag about the V160 and esso oil that have been discontinued. This is the email i got from them:
Hallo Mr. Falzon,
as replacement for the Esso ATF 21065 you can use a ATF Dexron 2 or 3 from Shell, AGiP, BP Castroll or any other supplier you can get.
Alternative to the ATF oil you can use a manual transmissions oil 75W 90 GL3. If you use this you will have maybe a little bit higher shiftforces at cold conditions.
If you have any questions pleas do not hesitate to contact me.
Mit freundlichen Grüßen / Kind Regards
Manfred Greiner
Fachbereichsleiter Versuch und Prototypen
Fon +49 (0)7131.644-4259
Fax +49 (0)7131.644-4256
[email protected]
What do you all think?
That 'special' V160 oil is no more than a standard ATF??
No surprise there. The only oil not to use is Redline MTL. For some reason this knackers a bearing or seal.
Royal Purple is supposed to be the best.... according to those 'in the know' ;)
V160 - If we can test this stuff and match it I am sure we can supply a cross matched oil for a lot less but I need a sample of it.
Cheers
Guy
http://www.turbosupras.com/pages/en/pages/technical/V160.htm
Royal Purple Synchromax - http://www.royalpurple.co.uk
Don't know what all the fuss is about. BMW, Maserati and GM all use versions of the same Gatrag box, all have their "own" oil for it. Analysis below, easisest to find is the BMW oil called MTF-LT-1
cSt@40 c 37.5
cSt@100 c 7.5
Viscosity index 172
SUS @ 100F 190.1
SUS @ 210 F 51.3
sliver
Boron 205
Aluminum 1
Calcium
Cadmium
Chromium
Copper
Iron
Magnesium 2
Manganese
Molbdenum
Sodium 2
Nickel
Phosphorus 484
Lead
Antimony
Silicon
Tin
Vanadium
Zinc 7
Total Acid Number 0.63 mgKOH/g
viscosity -cP @ -10 c 2116
viscosity - cP 2 -20 c H4757
viscosity - cP @ -30 c H 12347
viscosity - cP @ - 40 c H 38246
API 35
Specific gravity @ 60/60 F .8501
Lb/Gal 7.080
Thank you for your enquiry. After speaking with my contact over at EssoMobil I have found that the product isn't called Esso Dexron 21065 it is called Esso ATF D21065 with a Dexron Specification. Please find below full quotation for the Esso ATF D21065. A technical data sheet has been attached for your reference.
Esso ATF D21065- 1 x 20lts
£3.76 per litre
£75.20 per 20 litre
Delivery Period: Standard Delivery Period is 7-10 working days
Delivery Charge: Standard Delivery Charge is £15.00 (but is dependable on total weight ordered and delivery area in UK)
Payment Method: Debit Card
Credit Card (+2.5% Credit Card charge)
Cheque
Payment must be received in full and in advance.
Above price is for 1 x 20 litre container only.
Trusting the above meets your requirements, we look forward to your reply.
Best Regards,
The County Oil Group Ltd
Beca House, Ashville Way
Ashville Industrial Estate
Runcorn, Cheshire
WA7 3EZ
Tel:- 01928 718000
Fax:- 01928 716887
Guys.
Having had discussions with the Fuchs/Silkolene technical bods, this is in fact a Dexron II product (not Dexron III although Dexron III is supposed to be backwardly compatible)
The product we would recommend that you use is Fuchs/Silkolene Titan ATF3000 (Dexron II).
http://www.opieoils.co.uk/performance_lubricants/pdf/fuchs/TITAN_ATF_3000.pdf
Prices in the Members Section of our website are:
1L £4.49 & 5L £15.99
The Fuchs Titan ATF 4000 is a better quality product although not a DII but a DIII.
http://www.opieoils.co.uk/performance_lubricants/pdf/fuchs/TITAN_ATF_4000.pdf
Cheers
Simon
Guest Damien89
Well according to chris wilson you can use the BMW oil. I posted the answer from the enginner from getrag as it was the only choice i had to get a definite answer as to what oil to use. Maybe you can ask chris wilson about the BMW oil.
ya Chris Wilson seams to know alot about supras so i think when i finally get aroud to changing the oil ill have both on stand by and ill see what comes out of it!!! thanks for the info though and it makes sense to ask getrag.. never thought of it really!! by the way which part of malta are you from?? had some good times in Hal far.. not sure of the spelling but its the drag strip in Malta
Guest Damien89
Yep you spelled it right. I am from Qormi not far away from Hal Far. Good to hear that somebody has been to Malta in this forum.
  • 2 weeks later...
The syncromax goes real well with your boxes, its basically a ATF but with a better film strength so it is thinner than GB oils but give same/better protection
Got any proof? Sorry with 10 posts only I don't recognise your name and so I don't know why I should take your advice!
Not being an arse just would like more clarification on your technical knowledge and why you say it's good for our boxes...thus indicating you are A) not an owner and B) going by a 3rd party experience.
Thanks
  • 1 month later...
Just an update on this from a little research.
MTF-LT-1 is the fluid specified for Getrag 6 speed found in E39 540i and E39 M5.
Esso/Exxon MTF-LT-1 BMW P/N 83 22 9 408 942
MTF-LT-2 Fluid BMW P/N 83 22 0 309 031
BMW Service Engineering info - From model year 2004 some manual transmissions are filled with Castro "MTF-LT-2" lifetime fluid. This fluid has the same properties as the "MTF-LT-1" fluid indicated above in section D. The "MTF-LT-1" fluid may be mixed and/or substituted for the "MTF-LT-2" manual transmission fluid.
So basically any of the above should do as they are backwards compatable, I also remember reading on a beemer forum that Some M owners reported less notchiness when going to LT-2
Guys I have thought this for ages....people rave on saying this is the only stuff to use, grave danger if you use anything else. The way you need to look at it is that at the time supras were developed and made, oils and lubricants were very different to todays modern synthetics, over the past 13/14 years im sure oil companies have developed superior products which are more that suitible to use in older style gearbox's, diffs etc etc over and above what was around 13 years ago
LOL!
at last, I found it quite amusing that people could only use "v160" and paying stupid amounts of money as it's low on supply and the fact its got a toyota badge on it :rolleyes:
These forums make me laugh sometimes :) you really have to take everything with a pinch of salt with what people recommened as most seem to take it as gospel when typed out.
my supra's are serviced with rock oil, £4 per litre and superior to dextron 2 & 3 :) as appose to toyotas near £30 per litre.
  • 1 month later...
LOL!
I totally agreed with the taken as gospel comment. One reason why I started the thread http://mkivsupra.net/vbb/showthread.php?t=140375. It is good to hear from members who have used non OME products with out issue.
The only other issue that goes along with your comment about oil development over time is, are the 15year old seals compatable with more modern equivalents? I dont want to slavishling stick to Toyotas own product, I just want an oil that works and possibly makes the box even better.
  • 1 month later...
