HELP me connect my Greddy speed cut limiter!
123Kid
Ok there are 3 sensors according to the pin outs, SP1, SP2-, SP2+
There are two wires on this, Speed Signal (ECU) and Speed Signal (Sensor) going in a J-Spec MKIV A/T ECU.
Where to?!?!
Thanks Mates.
edit:http://greddy.com/img/PHP/products/pdf/809.pdf
The delimiter sits between the speed sensor and the ECU.
The speed sensor wire to the ECU should be cut, SPD (ecu) connects to the wire going to the ECU, SPD (sensor) connects to the wire to the sensor. Its not clear from your post if you also need the pinout number for the speed sensor wire, can you clarify?
Question for everyone else - Does the greddy one remove the limit, or one of the nasty ones that fools the ECU into thinking its going slower (i.e messes up power steering and active spoiler)? Can't imagine it is, but worth checking....
I literally cut the SPD (ecu) wire? shit it's gonna feel so wrong :( but I heard that before as well. Alright since the brown wire (SPD ECU) goes into SP1 (which is labeled E10 - Pin #2 ) That takes care of that (I think). But now there's the blue wire (SPD sensor) that either goes into (E9 - Pin #3) SP2 - or (E9 - Pin # 23) SP2 +
Correct me if I am wrong, thanks for all the help.
Have a look on here: http://mkivsupra.net/vbb/attachment.php?attachmentid=13919&d=1112558155
Check out E10 Pin #2, E9 Pin #3 and E9 Pin #23
  • 3 weeks later...
