FSE Boost Valve help...
scooby_doo_do
You run your fuel system without the engine running via a jumper wire in the diagnostics port and you use your gauge (be it mechanical or electronic) to see what pressure the fuel is running at. You then adjust the nut on the top of the valve to set it to whatever you want it to be.
Or you could bung on the FSE valve with no idea what it's set to - which with a sinking heart I suspect is what happens most of the time.
Of course you couldn't measure it now even if you wanted to as it's gone the way several other have gone before... Toyota stock is 36psi, you may want to aim for that. If you drive off boost you should be OK to get to somewhere with an EFI fuel pressure reading kit :) They can set it to whatever static pressure you want.
-Ian
