DEPO Racing Guages!?
Westy
 Share
  • Replies 60
long ago I got same looking boost gauge for my MR2 (although it didn't have the wired thing sticking out from the back). Pretty accurate as it has a stepper motor and looks nice with the "smoked" look while unlit. I can't remember exact price but it was around 20-30 quid from ebay.
The accuracy of a gauge is based on the sensor, not on the actual mechanism of the guage. You could use any old dross as the actual "gauge" the sensor is where the money needs to be spent for accuracy.
I checked my boost gauge and it was pretty good (within 0.2 psi @ 15psi) and it's what would be considered cheap crap (glowshift).
Ah right, not sure how accurate it was but the needle sweep action on startup won me over :p
I would be up for that. I want:
Depo Racing 60mm EGT, Oil temperature, Oil Pressure and Voltage 4 in 1 gauge
Depo Racing 52mm Boost Gauge
Depo Racing 52mm Water Temperature Gauge
All with black faces.
You got a link to the club aristo traders section where these are listed!?
Had a look at the Prolex website and given what's available I'm going to go for:
60mm EGT, oil temp, water temp, voltage 4 in 1
52mm boost with peak hold
52mm oil pressure with peak hold
Retail = £301.87 + P&P
Not bad, but I will email them and see if they will do a club discount!?:)
 Share
